Obi-Wan,
Explain for us…take us on the path of enlightenment:)
lol…me not Obi-Wan…lol
ground rods to play a part in a Equipo. when it deals directly with making something a EQUAL potential for touch and serves a great purpose in the agriculture industry…but in the efforts of a ground rod on a house.
It really only serves (3) purposes…
1.) To direct lightning ( high frequency ) to the earth to which it is trying to get ( lets not confuse Lightning with AC Current…Lightning is DC for the most part in this understanding )
2.) It serves as an additional fault current path for the POCO as they share it with their own in terms of aiding in clearing a HIGH VOLATGE/ HIGH AMPERAGE fault…but really it is in case their is a HIGH VOLTAGE line that comes in contact with the service drop…so to speak…and…
3.) A sudden IN rush of voltage from the high power lines itself in a surge…
The Ground Rod on the house serves those functions…
Now will a Ground Rod or to be frank ANY of the grounding electodes protect your inside equipment or devices in your house in a lightning strike…or surge to the high power lines…NOPE…a Surge Device or TVSS is the best line of defense on that part.
THIS is why it is so critical to have that Grounded conductor in place and a proper BOND…to allow the " stray " which are really simply electrons trying to get back to the SOURCE of their creation…
Faults Currents and so on as it pertains to the GES are not trying to get to EARTH…they are trying to get to the source…while they can travel within earth…creating a POOR parallel path back to the source…EARTH plays no real part in the dwellings electrical system.
Paul
Ground rods are to establish a path for current flow if one looses the neutral refference for safety. People are not a good path to ground.
The better the ground the less voltage a person will be exposed to if one were to lose the neutral refference
And that is what I think
rlb
Another myth…lightning does not strike metal because it is metal…notice how it strikes TREE’s all the time.
Lightning is LAZY…it strikes the closest object and it can originate from the ground or the sky…all depends on the + and - configuration of the elements.
WRONG…that is simply NOT the case…the EARTH will never conduct a good enough path to the source to cause a OCPD to trip…on standard 120/240 volt systems.
IN doing EQO planes this may be the case…it is NOT the case in ground rods for a dwelling…
YOU simply DO NOT drive a ground rod to reduce touch potential…in regards to a grounding system for a dwelling unit.
It only takes 5MA to kill you…so basically lets do the math…( Fixed my own CRAPPY MATH )
I grab onto a ground rod and grab onto a HOT wire with the other hand…are you saying the potential will protect me?
Assuming the ground rod has a resistance of 25 OHMS…120V dividided by 25 OHMS gives us 4.8A…will this clear a 15 A Breaker in time before it kills you…?
This is a wild misconception with regards to ground rods for a house…the ground rods at the transformer pole serves two functions…
1.) Voltage Stabilization so that when we test we accuratly get a reading
2.) TO allow high surges on the line or lightning to FAULT and trip the OCPD on the pole…which is very low…how can this happen…
Usually at the pole you have 7,500 volts for example…do the same math on a 25 OHM rod…7,500 divided into 25 OHMS equals…300A…normally the fuse on the pole can be between 5A and 50A…depending on the area…so will a 300 A blow a 5 or 50A fuse…YEP…
Dwelling grounding is a different beast
I think the most important thing a HI takes from this is the following-
The Ground Rod is not going to protect a house from Lighning Damaging the components inside. The function of the Ground Rod is to SHUNT the lightning which is a high frequency current to the earth which was IT’s original intent.
The Ground Rod of a dwelling is not designed to offer any fault protection…the EGC’s and Bonding Jumpers are CRITICAL in this function as they provide a EFFECTIVE and ASSURED path for these currents to get back to where it was intended to go in the first place…the source which is back at the transformer.
Earth can NEVER be used as an effective path for anything…while it may PLAY a path because we know that the old saying voltage takes the path of least resistance…fact is it takes ALL paths and the Ground MIGHT be one of them but it is not an effective one and is not the intent of the Ground Rod.
The intent was to NOT explain the potential POSSIBLE currents that COULD travel on the ground rod and earth…but most certainly a loss of the Grounded Conductor to the transformer would not aid in clearing any faults in the panel because of the ground rod, the earth is simply too poor of a conductor for that.
Hope this was helpful…those that do not agree thats is fine…grounding and bonding is something that is a VERY tough topic.
P.S. It is also important to note that IF it was a potential thing…the Transformer ALWAYS has it’s own connection to the earth to solve the potential issue…but again thats not it’s focus at the pole either…I explained that earlier as well.
Paul
Math on an open neutral (not the hot wire)— 120 volts 25 ohms = 30 volts thus not a people killer — Hard to get the .005 amp through the higher resistance of the body
This protection is only on an open neutral and a person in contact with the neutral and earth ground – ie water pipe etc.
Just thoughts
Never heard about voltage stabilization
Paul
Good question
Keep them comming
rlb
Incorrect statement Richard…VOLTS don’t kill…AMPS kill so 30 volts could very well kill someone.
But…the NEUTRAL on a OPEN service neutral richard would still be voltage at the end of that neutral wire…so it would still be 120V…provided you became the PATH…and doing that math…if you became the PATH you are still looking at 4.8A…
Now you are saying the body would aid in that…well the body is known to be roughtly 1000 OHMS of resistance…so lets do that math…
.12 AMPS…is that not HIGHER than 5 MA lets say that a GFCI protects a person…and WHY does a GFCI protect at 5 MA…thats .005 A because above that could KILL you.
The ground rod…or the body’s resistance is simply not going to protect a LIFE…the ground rod’s primary function is to protect the dwelling from lightning…but even in THAT…it is a reaching HIGH
The problem is the BODY goes into Ventricular Fib at VERY low levels and ironically the 60 HTZ we use daily is about the same FREQ as the hearts beat rythum…while the AMPS may not kill you…the FLUTTER of the heart will in a short time.
Well now you’ve stepped in it.:o
Equipment leakage current limits are different depending on equipment type and application. This doc describes the limits.
The smallest current limit is .010 mA and that is for medical equipment for a particular type of patient applied part.
By way of comparison your typical computer power supply can has leakage current limit of **3.5 mA **max. allowed.
http://www.condorpower.com/public/condor/pdfs/An113.pdf
I used to do this type of testing and evaluation for a living and have been involved in elctrical safety for over 25 years.
Not pounding my chest just explaining why I know this.
MY brother…YOUR posts are SO important to this topic because you bring VERY…VERY valid points…and only through bringing them do we learn.
I am sure the other electricians can add here…as I have been brief on explaining it…but is more so why MARC stated it is useless in most cases in regards to electrical in the dwelling so to speak.
ALSO…it is important to understand TIMING…with all that said and done…BECAUSE we are such poor conductors and the earth is such a poor path…all this translates into the OCPD never tripping…because it NEEDS to see amps in excess of its rating to TRIP and in a normal breaker it can need to see 6 TIMES the rating to TRIP…
This question SHOULD make people THINK about how electricity really works and why it can be dangerous…that was my overall goal.
Micheal…I will be sending that DOCUMENT much like I did on the IDEAL one that I found to Mike Holt…that statement has a BUNCH of ERRORS in it…
Are you telling me you think FAULT currents are SHUNTED to the EARTH via the Ground Rod in a house…I stepping in nothing.
Do you believe EVRYTHING you read as this myth has been around for years and years…in fact the article I submitted to MIKE HOLT which I will post was from IDEAL the makers of Ground Rod Testers and Test Equipment and they misunderstood the systems…and THEY MAKE THEM
And here is the ORIGINAL article…remember this is from the MAKERS of the SureTest and Ground Rod Testing Devices…
EDIT: I can’t find the original…I will find it and post it…BUT read the statements made by the industry leaders on these equipment and devices and THEN read Mr. Holts comments.
I sent this document to Mr. Holt…because of all the wrong statements within it…this document also has some major incorrect statements in it…THANK you for posting it.
UL 2601-1 now UL 60601-1 is the UL standard for medical equipment. Yes errors exist in standards but the limits stated are correct in this case.
UL 950-1 now UL 60950-1 is the standard for information technology.
I only meant you stepped in when you stated that .005 mA could kill you. Do you have a source for that statement. Perhaps it was a typo.
What myth? Did I miss a post. I will go back and reread. I was not addresssing ground rods only leakage current limits.
I think my DECIMAL points are wrong…what we are talking about is 5MA for a GFCI to function…in the use of a Ground Rod for a dwelling…
You are putting dedicated supplementary electrodes for voltage gradiants and so on in the same level…we are talking about the Ground Rod to a dwelling and its FUNCTION…
Ahhh…leaking voltage is a totally different thing but it plays no ROLE in the functional use of a ground rod and it’s intent and use.
Are you saying 5 MA could not kill you?
Lets not get people confused now Micheal…Medical Equipment with a isolated ground and so on is a different subject. While it can PUT voltage on the grounding system…it will make an attempt to travel to the source and thus through proper bonding of the system and through a PROPER path to the origination point…so technically we could say the WHITE neutral wire in a panel should have some " GREEN" tape on it also…( dont do that…was a metaphor )
But I love it…Keep it coming fella…IT’s all GOOD…but lets keep it to Dwelling fella…lol…not Medical Facilities…lol
I agree. I went off topic because of your kill you statement.
It sure can. I was reacting to your decimal point error which would be 5 micro Amps.
lol…and rightly so…I type for CRAP.
I actually like the article ( to a point ) that you posted but if you read the first few lines it talks about the LOSS of the grounded conductor…and the same effects will take place on ALL metal equipment and will indeed leak but this still goes BACK to the source…
COULD it go back through the EARTH to the source…YEP it most certainly can if that is the only way for it to get back because of the loss of the Grounded Conductor in the system…
Sad part is…it will TRY but the path is SOOOOO poor it simply wont protect anything so effectivly the Ground Rod is NOT effective in that senerio…
Micheal…you have NO idea how I thank you for brining that up…it really ADDED to the topic…Richard you as well…WONDERFUL stuff
