2-Day Training Seminar - St. Louis, MO
December 9th and 10th at the Holiday Inn-Select, in St. Peters, MO…the NACHI Caravan pulls in from Canada to offer another great session. Both classes start at 8:00 a.m. and run to 3:30 p.m. Fees are $50 for NACHI members and $100 for non-members.
For more info, see our chapter website at www.monachi.org
Day One - 12/9 is Plumbing for Home Inspectors. Here is the outline:
Plumbing Course Outline - 1 Day
(6 CEUs)
Course Overview:
[FONT=Times New Roman]Purpose[/FONT]
[FONT=Times New Roman]Elements[/FONT]
[FONT=Times New Roman]Application[/FONT]
[FONT=Times New Roman]Testing[/FONT]
[FONT=Times New Roman]Evaluation[/FONT]
****Note: ****As a pre-requisite, the inspector should have clear understanding of their association’s Standard’s of Practice and Code of Ethics and/or their State/Provincial inspection guidelines, where applicable.
Plumbing Introduction****:****
[FONT=Times New Roman]Definition of Plumbing [/FONT]
[FONT=Times New Roman]Components of Plumbing – Water Supply, Drain, Waste, Venting, Fixtures, Appliances, etc.[/FONT]
[FONT=Times New Roman]Standards of Practice - Refer to Industry Associations[/FONT]
[FONT=Times New Roman]Code of Ethics - Refer to Industry Associations[/FONT]
[FONT=Times New Roman]Inspection Tools & Application[/FONT]
[FONT=Times New Roman]Inspection Techniques, Safety, Reporting Methods & Qualifying the Client[/FONT]
Types of Plumbing****:****
[FONT=Times New Roman]Materials Used in Plumbing – Copper, Lead, Galvanized, ABS, PVC, Pex, Poly-B, Combination, etc.[/FONT]
[FONT=Times New Roman]Pros & Cons of Each Type[/FONT]
Styles of Plumbing****:****
[FONT=Times New Roman]Designs – City (Municipal) vs. Rural (Private) Application[/FONT]
  • Soldered Joints vs. Compression or Crimped
    Pros & Cons of Each Style
    [FONT=Times New Roman]Combining Styles - Common Combinations[/FONT]
  • Considerations
Plumbing Systems:
[FONT=Times New Roman]Water Supply – Curb Stop, Main Shut-off, Water Meter, Distribution Pipes[/FONT]
Drainage – Main Clean-outs, Stack, Traps
Venting – Dry vs. Wet
Cisterns, Wells & Septic Systems
Mechanicals – Hot Water Tank, Expansion Tank, Pumps, Humidifier, Appliances
Valves, Fixtures, Faucets, etc.
Plumbing Pluses:
Frost-free, Anti-siphon devices, Isolation Valves, Steel-braided Hoses, Insulation, etc.
Plumbing Deficiencies:
[FONT=Times New Roman]Defect Recognition - Recognizing Problematic Areas, Workmanship Quality, Weather, etc.[/FONT]
[FONT=Times New Roman]Reporting Concerns & Issues for the Inspector[/FONT]
Question period / Open forum
Evaluation:
Course Evaluation form handed out for completion & return (includes comments & suggestions)
Day Two - December 10 is Framing for Home Inspectors. Here is the outline:
[FONT=Times New Roman][size=5]Framing Course Outline - 1 Day
(6 CEUs)
[/size]
Course Overview:
Framing Introduction****:****
[FONT=Times New Roman]Definition of Framing [/FONT]
[FONT=Times New Roman]Components of the Framework – Structural Supports, Floors, Walls, Ceilings, Roofs, etc.[/FONT]
Types of Framing****:****
[FONT=Times New Roman]Materials Used in Framing - Wood, Metal, Combination[/FONT]
Styles of Framing****:****
[FONT=Times New Roman]Designs of Construction – Stick Built & Balloon[/FONT]
[FONT=Times New Roman]Pros & Cons of Each Style[/FONT]
  • Considerations
Framing from the Ground & Up:
[FONT=Times New Roman]Support Beams & Posts, Sill Plate, Rim/Band Joist, Floor Joists, Blocking, Sub-floor[/FONT]
Wall & Nailer Studs, Cripple & King Jacks, Headers/Lintels, Upper & Top Plates, Wall Sheeting
Ceiling Joists, Rafters, Trusses, Roof Sheeting
Framing & Next Steps:
Insulation, Vapour Barrier,
Framing Deficiencies:
Evaluation:
[/FONT]
Do you guys need an RSVP? I have a family member that may be released from the hospital that day. I may be needed and will not know until Friday.
What do you need as proof of NACHI membership?
Jeff,
I would guess you could PRINT off this page showing the NACHI Member part under your name…that would probably work or the NACHI ID Card…but mine has expired…lol
What would you guess?
I would GUESS that that would work…theehhee…
Jeff—You can attend both or either of the two days. One is dedicated to plumbing and the other framing. Larry Krausz will know you are a member when he checks you in. Hope you can make it. RSVP is requested, but not required.
