Originally Posted By: jfarsetta
Bob,
However, you CAN connect such apparatus using an adapter.
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Joe Farsetta
Originally Posted By: Bob Badger
Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
Originally Posted By: jpeck
Mike Parks wrote: |
Erol
I am glad that you asked. Most will not ask. The "white" wire is called the "grounded" conductor, so the oulet is grounded. Mike P. |
Mike Parks wrote: |
The "bare" wire is the egc (equipment grounding conductor). This is the 3rd wire in a 3 prong system.
Mike P. |
Mike Parks wrote: |
As far as safety-- go to your TV or a lamp and look at the plug. The big blade is the grounded conductor.
Mike P. |
Mike Parks wrote: |
Ground, grounded, grounding, bond, bonded and bonding is something "we" argue about all the time.
Now to confuse you more when the ground is missing they are taking about the egc. I won't even start taking about the "neutral". Mike P. |
Jerry Peck
South Florida
Quote: |
250.138 Cord-and-Plug-Connected Equipment.
Non?current-carrying metal parts of cord-and-plug-connected equipment, if grounded, shall be grounded by one of the methods in 250.138(A) or (B). (A) By Means of an Equipment Grounding Conductor. By means of an equipment grounding conductor run with the power supply conductors in a cable assembly or flexible cord properly terminated in a grounding-type attachment plug with one fixed grounding contact. |
Bob (AKA iwire)
Originally Posted By: jmyers
Bob Badger wrote: |
... I agree the two wire outlets themselves are not a hazard ... |
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Robert O'Connor, PE
Eagle Engineering ?
Bob (AKA iwire)
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Jerry Peck
South Florida
Bob (AKA iwire)
