200 amp panel 100 amp service
New 200 amp panel and the 200 amp breaker is not being used. The 100 amp breaker to the lower right is now the main breaker. First time I have ever seen this. How do I write this up?
There’s nothing to write if the 100A breaker is properly installed. It needs to be secured in place. Identify the service as being 100A.
I agree with George, and I’ll add, if the 100 amp breaker is back-fed it needs to be secured (screwed) in place.
I found this one yesterday that wasn’t.
Image please.
You write it up as a 100 amp service. There is nothing remarkable about using a 200 amp panel at less than its rating.
