240 volt dryer receptacle.
How do you test these?
Turn on the dryer or use my Electrician’s tester with probes .
lick test…never fails…
Well turning on the dryer wouldn’t let me know if it was wired correctly.
Can I watch the next time this should be very exciting to see.
Thanks for the chuckle
If I can’t get the wiggy to work that is…
With one of these
http://i1.quinbyhardware.com/6311914.jpg
Cheapest tool in my bag next to my great interNACHI microwave tester.
I also use it to check for proper line/load wiring on the A/C disconnects.
Test across the line should read 240 volts, test each line to neutral should read 120 volts, same thing to ground, 120 volts if a 4-wire system.
Why do you feel the need to test the wiring on this? Did you notice something in the panel?
Thanks
Lol because I’m a home inspector :wink:
Thanks guys :slight_smile:
Very funny :smiley:
Although not as reliable, you can use your NCVD, just like when you (if you) check non-grounding type receptacles.
Be sure to check for reversed wiring as that is the most common issue.
:slight_smile:
Huh?
You can’t reverse 220 VAC
Guess ya did not catch the smile;-) but yes you can swap them around all ya want just does not change anything:D:p
You mean the dryer won’t run backwards?..:roll:
Mite if it wuz 3 PH:p
Technically you can, it just won’t make a difference.
I do believe he meant Line to Neutral and vicy versa, or Line to Ground, or Ground to Neutral, et cetera.
Merely a flesh wound, I missed this post.
Guess you know Mr. Larson :roll:
