4 point Wiring Aluminum
Jesus,
Do you have a question we can help you with? Do you have a concern about the aluminum service entrance conductors in your picture?
Wire Type is talking about cables coming from outside or those going inside the house.
They are asking about the circuit wiring inside the house. Practically all Service Entrance Cables are aluminum. Not much point in asking about them.
So in the 4 point where they say wire type I have to put aluminum
No…
Not…
The 4 Point Report asks your observation for all wire types:
Copper
Single Strand AL
Multistrand AL
Copper Clad AL
Cloth (knob & tube)
Cloth Jacket Rubber Insulated
NM, BX or Conduit
Other
You simply have to figure out WHAT type of wire in your posted picture
My 4-point has seperate sections for branch wiring and SEC in order to avoid confusion. Branch wiring is the only section that they want to know if it is Multi / single strand and what it is used for.
Yes.
Are you using the 2025 Four Point report? The 2025 Four Point report has a checkbox for stranded aluminum in the panels section. You need to check that box. No commentary is needed. Ahead of that, it asks about branch circuit wiring. Refer to the attached screenshot.
The 2025 Four Point asks whether single strand or multi strand is present in a panel. It is not limited to branch circuit wiring in the panel section. The report first asks specifically about branch-circuit wiring, and later asks about the presence of any aluminum wiring in electrical panels. You must report on any aluminum wiring.
Thank you everyone for your help :folded_hands:
Which version of the Four Point report are you going by? The 2013, 2018, and 2025 Four Points all require listing all aluminum wiring. This is from the 2013 Citizens Four Point:
“Aluminum Wiring*
*If present describe the usage of all aluminum wiring.”
It covered single-strand aluminum specifically in another section within the electrical section.
The 2018 Four Point rearranged the electrical section. Branch circuit aluminum wiring is addressed specifically under “Indicate the presence of any of the following:”
The Panels section specifically asks whether any aluminum wiring is present under “Wiring type”.
There was a lot of confusion among inspectors about the “Wiring type” section in the 2018 Four Point with both cloth wiring and aluminum wiring. The 2025 Four Point changed the single “Aluminum” checkbox to two checkboxes: “Single strand” and Multi strand” and it added boxes to further clarify what is meant by cloth wiring.
I don’t remember what it was before 2013. I’d have to dig deep into my archives, but Citizens has required identifying all aluminum wiring for at least the last 13 years.
Since 2018, every insurance company has used the Citizens Four Point report. Before 2018, the only major insurance at would not accept the Citizens Four Point was State Farm. The 2013 State Farm Four Point. Had a section heading “Indicate ALL types of wiring in the home and all other structures” “ALL” in “ALL types” was in all capital letters to emphasize that all wiring was to be identified. There was a checkbox specifically for aluminum.
If you are going by one of the old Four Points like the Tower Four Point or others, they are all obsolete and not Citizens compliant.
“My 4-point has seperate sections for branch wiring and SEC in order to avoid confusion:”
I feel like you may have missed this part. SEC would be labled Multi-strand aluminum already. Then you would only have to lable what BCW is used for. Thus…the avoiding confusion part.
I use spectora 4 point 2025
You also said:
I don’t know where you got that idea, but that’s an unequivocally false statement. A major problem with the Four Point is that, unlike the 1802 Wind Mitigation report, the requirement is only that the information required is somewhere in the report. It is not required to be in the Citizens format. The problem is that most inspection report software developers don’t understand the insurance industry and they especially don’t understand Citizens.
The complaint I hear most often from insurance people is that they have trouble deciphering all the different Four Point reports that they get. Consequently, home owners often do not get the best available rates. Inspectors like to defend their reports by saying “I don’t get any reports kicked back”. Of course not! A Four Point report that is not 100% Citizens compliant means that the insurance company can charge more for a policy.
The real problem arises when a homeowner can’t afford insurance from a traditional insurance company and has to go to the insurer of last resort, Citizens. While the Citizens report format is not specifically required, as it is with the 1802, they can refuse to write a policy if it isn’t crystal clear to them that the house is 100% complaint. That includes identifying all aluminum wiring.
To further aggravate the problem, Citizens has been overwhelmed with applications for the past year or so, so they are rejecting applications at historic rates. Almost every major insurance company will tell you that their #1 preference for Four Point reports is my WindSurance reports because they are not only 100% Citizens compliant, they are in the Citizens format. Some insurance companies have hired their own inspectors and use my software exclusivity because consistency across all Four Point and Wind Mitigation reports is extremely important to their efficiency and accuracy.
While you may think that having separate sections eliminates, or reduces confusion, based on what you have said, I can absolutely assure you that you have not made anything clearer and you are very much mistaken believing that they only want to know about branch circuit aluminum wiring. Identifying ALL aluminum wiring has been a requirement in all three Four Point revisions since 2013.
You would do yourself and your customers a huge favor by using a Four Point that is in the Citizens format.
And yet, you still only single out a piece of what was written. You seem to suffer from selective reading. Quote the whole thing and see if it makes sense to you.
I didn’t respond to you directly, so I will try again. The citizens form specifically states that you are not required to use that form, but provide at least the information required. By not specifying that the multi-strand aluminum is at the SEC makes some ( less instructed) under writers create issues. They do it with the branch wiring as well. It is specifically stated in the under writing guidelines ( which I have posted here in the past) that Multi-strand aluminum wiring is not an issue. Lear( :))to read!
I found two sample Spectora Four Point reports online. Neither of them is Citizens compliant. That may be the source of your confusion. The requirements are clear in a fully Citizens compliant report.
What are you on about. Spectora had the statement about identifying branch circuit aluminum wiring and what it was used for before it became a requirement. I can literally show you an inspection from 2019 to that has the same verbiage as it now has. I am not sure what template you are looking at. The only thing that is different in the template is stating the age of PEX. You can look through the posts and see I commented on it. Citizens will take any report as long as it has the minimum that they require. You are doing a disservice to say otherwise.
Certified Master Inspector
1h
You also said:
Have you ever seen single strand wiring for an SEC. Seriously, what is wrong with you. You are CMI and this is your advice?
