“The bolt must be located at least seven bolt diameters from the end of the plate section.”
What dimension is this? I have never heard or can find in my research a “7 bolt”.
Read and comprehend the statement AGAIN…
NOT…
Details matter!
For example for a 1/2" bolt.
1/2"*7 = 3 1/2" minimum distance.
Sounds like you are doing one of the IRC classes from INACHI? When you encounter something you don’t understand, this is a good example, quickly Scroogle search it. In this example anchor bolts come in various sizes but the typical on a home hovers around 1/2" diameter. They show the size in diameter which is part of the “seven bolt diameters” requirement and you will see what they mean 7 X .5" = 3.5" from the end of the plate. It’s safe just to use 3.5" as the figure when inspecting.
When you inspect and find the anchor bolt is only 3" from the end of the baseplate, and it appears to be a 1/2" diameter bolt, then use a little reason there as well. I inspect to the building Codes for new construction and wouldn’t write that up myself. That 1/2" is not going to make a difference. There are other things that I do get “By the book” on but those are more critical than the anchor bolt issue.
Have fun in your class and if you want to learn a whole lot about building then learn the Building Codes. Just researching what they meant in the Building Codes can teach you a whole lot about building/construction and inspecting even though you may not inspect to the Codes.
Understanding the INTENT of a given Code is likely the most important factor for an inspector.
It will also help keep your arse out of the chit with Builders you may come face-to-face with.
It also helps your professionalism and gains respect from the AHJ when you bump into them… because the Builder threw you under the bus!!
If you can get the commentary book that goes with the code it helps explain the reasoning behind the code.
A useful book to look at is the NAHB (National Association of Home Builders) “Residential Construction Performance Guidelines” if you intend on doing any new home or 11 month Warranty inspections. It gives some reasonable guidelines for a new home buyer to expect from the builder.
It gets updated but you can usually find a free version online.
If memory serves, this is covered in one of the “pre-certification “ courses. The OP has only been on the MB for a couple of weeks with less than 1/2 hour of reading time. Maybe they are new to all of this…. ![]()
I didn’t know they made that part of the pre-cert classes. Thanks for the info.
My memory did serve me well on this one.
It’s in the “25 Standards Every Inspector Should Know Course”. The pdf version has it on page 46 of 117 with this graphic and text,
There should be at least two bolts per plate section, with one bolt located not more than 12 inches, or less than seven bolt diameters, from each end of the plate section.
Aaaaaaaand on page 47 with a picture of InsterNACHI’s very own @kshepard
