a/c duct in contact with Type-B flue
Originally Posted By: srowe
I know these vents are not supposed to be incontact with combustibles but is the ductwork “combustible”?
![](upload://rB29NEiOJ8NnCZrZoyDYxtJGyKf.jpeg)
Originally Posted By: cbottger
Yes Shawn you are correct the duct should not touch the vent pipe but I can state from experience that foil backed insulation has a very high combustion point and virtually does not ignite the insulation beneath the foil will burn before the foil. I have personally tried to burn this kind of insulation in my trash barrels and it stays around for ever. Trying to stay away from code issues such as this as a inspector I do not make these kinds of calls unless I was to see evidence of heat on the insulation but that is your call.
Don’t argue with an idiot someone watching may not be able to tell the difference.
Thanks Charley,
It's a one year warranty and the owners want everything good and safe.
Thanks again.
