Anybody have any input on what is causing the heat pattern on this Freezer condenser unit? possibly a blocked or defective coil?
A blocked coil does not make heat;-)
According to the temp reading, it’s not really heat, it’s just relatively warmer.
Thanks, the more I look at it the more I’m thinking it isn’t a problem, seems to be a section of the coil that is fed off the receiver so its probably fine. Thanks for the input.
It’s too cold to be running the A/C anyway…
