Originally Posted By: tallen This post was automatically imported from our archived forum.
It’s the same as your car . It is a sealed system ,and unless there is a leak or some other problem all is good. Wait for it>>>>>>>>> here come the pros
– I have put the past behind me,
where , however, it now sits, making rude remarks.
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
I am no expert but I agree with Todd.
First it is not coolant like in a car radiator it if refrigerant like in a cars AC system.
Considering the compressor used on home ACs is a Hermetic Refrigerant Motor-Compressor it is truly a sealed system.
Quote:
Hermetic Refrigerant Motor-Compressor. A combination consisting of a compressor and motor, both of which are enclosed in the same housing, with no external shaft or shaft seals, the motor operating in the refrigerant.
As you can see by the definition there is no shaft seal to leak which is a problem with car AC compressors.
With the entire system copper or other metals as long as it did not leak when installed it should not leak ever unless some one damages a line.
By the way Bob I love your posts. You and Joe seem to be able to quote the NEC without having to look it up. I find that amazing I was a Sparky for a long time and I still find that I must look it up before I am ready to give answers.
You guys are definitely Masters of the trade. I am glad you guy's are here.
-- I have put the past behind me,
