These are not inspection oriented, but more personal. Not sure what may be the causes. One is at my rental, and the other is at a friend’s house. First, at my rental, there seems to be power to a couple outlets but when plugging something in, no power goes to the appliance. Also, the GFCI (which doesn’t feed anything else) has power to it but it won’t reset. Even when I replaced it. Now for the friend’s. Power to a switch, but when turning on the switch (which has been replaced twice to make sure it wasn’t the problem) the power disappears and the tester senses nothing. Any advice? Don’t have any pictures.
Hire a qualified licensed electrician. ![]()
Second Dave’s recommendation. Out of curiosity how are you verifying power to the switch and receptacles?
The first thing I would do is look at the outlet where you are having problems. Pull it out to look at the connections. A bad connection can have Voltage present, even a full 120V, but drop to zero or some level at which your appliance won’t work when you apply a load.
Outlets are daisy-chained. Assuming you did not find a problem at the receptacle where you are having trouble, look for other outlets on the circuit (all types, not only receptacles) and try to locate the one physically closest to the supply panel. From there, I would look to see which is the last in the circuit to function properly, working towards the one where you are having trouble. If you aren’t sure of how the circuit is laid out, start by looking at outlets on outside walls. They are the most susceptible to having loose connections. Electricians take the most direct practical route from the panel to the last outlet on a circuit.
Pull out the last before the one where are having problems and check its connections. You will probably find your problem there.
You will almost certainly find loose connections at either the outlet where you are having trouble or the one immediately preceding it.
I strongly suggest that you check the integrity of other connections if the receptacles have been quick-wired. Those are the receptacles where the wire is pushed in from the back and and the contact is made with a spring. There is a less common type that doesn’t require stripping the wire. Those are typically wired from the side.
When replacing receptacles and switches. I recommend use devices that use saddle connectors (similar to what Square D breakers use). They provide the most secure connection.
If you have a Wiggy or other solenoid type tester, use it. Don’t use a high input impedance tester like the plugin type or any other high input impedance tester. A Wiggy puts a small load on the circuit. You can often tell by feel when there is a poor connection. A Wiggy vibrates slightly and there is a distinctive snap when the indicator moves. When there is a bad connection, high input impedance meters can still indicate 120V, but with a Wiggy, you will feel less vibration and the movement of the indicator will have a softer snap. One the many great things about a Wiggy is that with a little experience, you won’t have to actually look at the indicator. You can feel the difference between 120V and 240V or when you have low Voltage.
Follow exactly the same troubleshooting instructions that I gave you in my previous message. Switches can certainly fail, like anything else, but based on your descriptions, the most likely cause is loose connections at receptacle outlets.
That’s true for your GFCI problem too. There could be a problem upstream of the GFCI.
I would normally agree with that advice. That’s the advice I would have given to a non-member. This is a good learning opportunity for David, especially as the owner of rental property.
The problem with hiring an electrician is that the average electrician isn’t good at troubleshooting. I’ve known of many people who have paid hundreds of dollars for exactly this type of problem because most electricians will just start replacing stuff until they eventually find the problem. I can isolate and repair problems like that in well under 30 minutes at least 90% of the time.
“qualified” .
Without prior experience with any contractor… please share with us how one goes about finding, (and hiring), a “qualified” contractor?
Electricians can be qualified yet have no troubleshooting skills whatsoever. They are qualified as electricians, but not as diagnosticians. Troubleshooting is not part of the curriculum for apprenticeship, journeymen, or master electricians. They get minimal education in electricity. That is especially true of residential electricians.
There are obviously some who go beyond the requirements of the trade, but how is a consumer to know which ones they are?
I have taught electricians at all levels for decades. I’ve had electricians with 40 years in the trade attend my classes who didn’t know what power factor is. They probably heard the term many times but most can’t give a good working definition, let alone how to correct a poor power factor. I’ve had master electricians ask why digital VOMs indicate 120V but a d’Arsonval meter doesn’t.
One of the guys on this board, who is a nominee for inspector of the year, and says he’s a journeyman electrician, didn’t understand what a Multiwire Branch Circuit is. He argued with me even after I pointed him to the NEC which has a clear definition. His response was that he was going to mute me. I have had master electricians who don’t know how to use a megger or a high-pot. I have had master electricians literally believe that an electron in a circuit travels the complete length of the circuit from the source, through the load and all the back to the source. I have had master electricians not know why high Voltage lines are not insulated. They don’t understand what skin effect is. They don’t understand harmonics. They don’t understood resonance. They don’t understand capacitive or inductive coupling. That’s how little electricians really know. Yet, they all are “Qualified” as electricians. The reason is that they are taught how to build electrical systems. They are taught how to look things up in code books. They are not even taught code theory. They are not taught how electricity works except at a very fundamental level.
Contractors will cheerfully send out a qualified electrician to troubleshoot a problem and charge by the hour as the electrician fumbles around until he eventually finds the problem. A homeowner can easily end up spending hundreds of dollars for a problem that should have been diagnosed and repaired in 15 minutes.
I’ve heard Bill Gates talk about the early days of Microsoft. He said they he and Steve Ballmer would interview potential employees together. They had one interview question. “In a circuit with 4000 nodes, what’s the maximum number of steps needed to isolate the problem?” He said that if they didn’t immediately know the answer, they weren’t Microsoft people. Anyone skilled at any kind of troubleshooting should know the answer to that question without much conscious thought. It should be like asking a high-schooler what one plus one is.
That is assuming that specific circuit power flows from one outlet to the next in sequence from a single power source.
Not mentioned is the possibility of the GFCI being wired to the LOAD terminals and not the LINE terminals. All GFCIs need to be reset upon installation, if they are wired to the wrong terminals they will not reset.
Robert, I don’t understand what you mean. All outlets on all branch circuits are wired in parallel in a daisy-chain. Please provide an example of when they would not be Daisy-chained.
I could be mistaken, George.
Instead of an outlet routed through outlet terminals by daisy chaining, a separate pigtail conductor branches off to power a single outlet.
Maybe i am explaining myself wrong.
Quote your Copy&Paste source!
No sir. Not at all.
Discussed on the MB various times.
You ever hear of notes?
That was actually the first thing I checked and it was correct. I was hoping that was the cause🙂
Thank you all for your input. George, I appreciate it! I did find an outlet that was reversed but I’ll get into it a little deeper. I’ve done quite a bit of electrical work over the years but I do have a highly qualified electrician that I trust that I can call if I need to. I just don’t want to spend the money if I don’t have to.
Both of the configurations you described are daisy-chains because one device follows another with their being only one home-run. The better choice of the two is to use pigtails, but since the advent of push-in terminals, it is rare to see electricians use pigtails unless pigtails have been specified by the builder. Pigtails use more material and take more time, so there aren’t many electricians who will do them on their own and there aren’t many builders willing to pay a few hundred dollars more for pigtails.
If they weren’t daisy-chained, each outlet would have a separate home-run back to the panel.
That’s a dilemma, it’s good to have a network of trusted folks. People ask me all the time if I know a good “xyz tradesman”. I just say no 95% of the time.
I agree with George it takes a special person to troubleshoot, evaluate and effectively repair electrical systems. On new construction when repairs are needed, the original installer "fixing " the Fups is not recommended. In which case I add “A properly supervised qualified licensed professional”.
When I open a panel and see stuff like “kit oulet”, “refri” and/or “landry” it’s a sign.
