Heating with wood can be challenging because it takes more active involvement than with other heating systems. Special knowledge and skills are also needed to successfully use this hands-on home heating option. If you heat with wood or are considering doing so, this comprehensive guide will provide you with the information you need to make sure your wood heat system is safe and efficient. You will also find helpful tips on how to effectively operate and maintain it
