Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
Yup Jay, you see CTs used on most services over 400a or to drive the meter. These are just a smaller version used for some kind of monitoring. I have some even smaller on my motion lights that will feed a low voltage monitoring system I am setting up.
Originally Posted By: rcooke This post was automatically imported from our archived forum.
CT are great for magnetizing a screw driver.
Put a steel screw driver in the centre of the coil touch the two leads to a Direct Current supply
(example a car battery) you now have a magnetized screw driver.
To demagnetize it put the screw driver in the coil and touch the leads to an AC supply and you have returned it to a regular driver .
Highly recommend you do not use 120 volts for this .
A bell transformer should do it .
Does not have to be a CT just about any coil will do and for DC a flash light battery works too.
