AC Breaker Sizes Minimum
2014 York AC calls for a minimum of 23.7 amp minimum circuit ampacitiy and maximum overcurrent protection 40.
The panel legend shows the AC is on a 20 amp breaker. I believe you are supposed to round up not down. Is this being overkill/pedantic or should it be rounded to a 25 amp breaker minimum?
I think Robert has a very good reputation. I believe he answers your question.
Thanks I was hoping he would chime in I’ll definitely read what he said
Good forum I read through most of it.
The OCPD should be a minimum of 25 amps. Having said that it will probably run for a long time on the current 20 amp breaker. The nameplate current at 208 volts is 17.9+1.3=19.2 amps. Run that unit at the normal home voltage of 240 volts and the current will drop by the ratio of 208 to 240 volts so 208/240=.867 19.2*.867=16.6 amps. Put an ammeter on the circuit conductors when it running and it should read approximately 16.6 amps.
All of which is fine and well for an AC tech or an electrician BUT the manufacturers installation requirements trump all of that. I would write it up.
I agree. It’s wrong and needs to be corrected.
I thought so but wanted to be sure. Apparently 25 amp breakers don’t exist in the hvac vans
Good point about the 25 amp circuit breaker. Although 25 amps is a standard size and are readily available it seems like many installers don’t use them (think hot water heaters). In this case a 2P-30 would be just fine.
