Acrocrete/Acrodry
I have a customer that is looking to buy a new home. It has Acrodry base coat stucco that appears to be releasing from the CMU walls. I am trying to do some investigating on this Acrodry product and have found no good results. Does anyone have any technical information on this product? I am looking in particular about the application and CMU/Concrete surface preparation. BASF is the manufacturer now but prior I believe it was Degussa. The work was done back in 2004/2005.
Thanks,
Jeremy
Start here;\
http://construction.basf.us/index.php?page=residential_products_products&select=15:)
Marcel,
Thank you for your response. Unfortunately, I have been to their website and the information is very general. I downloaded the technical data sheet for the product but it is unfortunately very vague and is only 2 pages. Any other suggestions would be greatly appreciated.
Thanks,
Jeremy
It says it can be applied to masonry, so you might have to call the # in the above link.
http://www.acrocrete.basf.com/en/lit/productbulletins/base_coats/Documents/PB_AcroDryBC.pdf:)
regardless of product
code and numerous plaster, cement and stucco industry associations have minimum installation requirements
when these aren’t/weren’t implemented systems fail…
any prior instructions are pretty useless by the time failure is observed
