Adding plumbing in existing concrete floor
Brand new house, in the building process. Concrete basement floor has been poured. Builder forgot to add plumbing for wet bar. Drilled holes in the slab to add plumbing. Any problems with this? Not a post tension slab.
Then there should be no issues, except (perhaps) moisture intrusion. . .
it’s done all the time. the slab is sawcut, the earth trenched, plumbed, backfilled & the concrete placed & finished.
sub-slab should be prepped – compacted earth & vapor barrier. also, rebar gets drilled into existing slab every foot or sixteen inches so that it will not let the new concrete sag.
I agree Andrew I had this same thing done in my house changeing out old cast pipes not a problem at all
