Narrowest stairs I’ve ever seen! House built in 1923, only stairs to second floor off kitchen.
where would you even put a railing? A rope might be better!
That’s right 2 foot 2 inches!
Go up on your knees. The riser looks higher than the tread is wide.
Is it possible that the second floor was an unfinished attic originally? A lot of older homes had full stairs to the unfinished attic, but they were not required to be as wide as a normal stair might be?
I’ve seen people wider than those stairs!
Who needs one? You can just span and push both sides for stability…
Two rooms with closets on second floor.
Won’t help you much in a fall.
Of course it had all the early essentials of electricity 101.
