Air gap on a vent with a hose going to a water filtration system
I’ve never seen this setup before in an attic or anywhere really. Any thoughts on this?
Possibly to back-flush the filtration system?
Yup, assuming it is a Reverse Osmosis System.
Even though you’re in Houston you still get the occasional freeze, I always call out water lines in the attics for this reason.
Around here these systems are normally installed under the kitchen sink or in the basement when filtering water for the water dispensor and ice maker installed in the fridge.
An option to prevent freezing and possible damage is to wrap the line and in this case also wrap that P trap in thermostatically controlled heat tape to prevent them from freezing.
