Aluminium Wires
While inspecting inside the panel, pay special attention to the branch wiring if you see that the neutrals are solid Aluminum wires.
Remember when we used to share tips here?
:mrgreen: WOW What a novel idea Thanks Brian!!! Sharing tips
Oh and BTW I learned my lesson on that all it took was missing aluminum at the sub panel and I now double check
Panels have a lot to look at inside, its not a time to be in a hurry.
I like to inspect the panel early in the process to get an idea of what all is wired in the home and always take a few pictures.
Or an unusual amount of pigtail type splices.
Good one Bill. That always gets my atention.:slight_smile:
Check out the link on Aluminum and Knob and Tube wiring
Its added to my web site
http://www.esasafe.com/consumer/sn-001.php
Today
What is the tip?..:smiley:
:smiley: …Barely…:smiley:
http://www.inspect-ny.com/aluminum/aluminum.htm
Here is a tip…some nice info on this site regarding Aluminum Wire.
](http://www.esasafe.com/consumer/sn-001.php/quote) Robert, ??:frowning:
ESA keeps changing the pages this one now links
http://www.esasafe.com/pdf/Flash%20Notices/97-04-01-FL.pdf
Knob and Tube
http://www.frontlines247.com/FrontLines247Info/esa/Attach/Answer12-26-7_03-02-FL.pdf
Thanx Robert:D :smiley:
Your welcome but if you link it watch it as they keep changing the pages…drives me nuts.
From an inspection last week
I see that one conductor in the middle of the back row is heated up pretty nice. Luckily for me, there weren’t many aluminium branch circuits installed in my area.
First one I’ve ever seen. Luckily, they’re not that common around here either.
Neato
