Hey everybody, I am not yet a certified inspector but I am hoping to become one by the end of July. I wanted to ask the more experienced inspectors if they could explain when exposed twisted aluminum wire (like the incoming neutral) is allowed in the panel. In my home I have three examples of this in addition to the incoming neutral and I have no idea why, what they are for, or their legality.
Also, I noticed the following things as defects/write ups.
1: There is old cloth wiring in the panel that is heavily deteriorated.
2: There is a double tapped breaker.
3: The wire on the bottom of the picture is not live. Non live wiring that is not being used should be removed by a professional electrician.
4: There is electrical tape around part of one aluminum conductor, and old/mismatched tape/insulation around other wires.
5: Not pictured, there was mild rust on the dead front panel. Due to the age and deterioration of the panel it is recommended to be evaluated/updated by a professional electrician.
Chris, if you haven’t taken the Internachi Residential Electrical course, I suggest you do. You may then want to proceed to the advanced course.
Good Luck
Thanks. I remember that now. I need to look into it more. I have completed the first electrical course but I need to review it and then do the advanced one. I’m still training I am not claiming to know it all!
I have completed the residential and plan on reviewing more and taking the advanced afterwards. I didn’t know there was an advanced one. I am new to this. Thanks.
