Am I supposed to
Hey yall, new member here and I have a question. Had a client just reach out and is angry because I didn’t specifically tell him that the data tag was missing on the water heater. I did however state in the report that the age and serial numbers were unknown and that it needed the tpr valve reinstalled properly. Am I supposed to tell them that the data tag is missing specifically or what I did is acceptable?
You should add a narrative to your template. When the data tag is removed, it is a possible (likely) that the unit was defective and replaced under warranty. Some (most?) manufacturers simply ask for the data tag to be sent back, before sending a new replacement unit. The unit could be working fine (and the data plate fell off - harrumpph), but it would be best if a licensed plumber check it out (which would be your recommendation).
Welcome Richard!
Although a petty issue, it’s best to state why you couldn’t determine the date. Many times there is data tag located where you can’t see or get to. Best practice is to state why it can’t be identified. Best bet is to make amends with the client by apologizing that you failed to mention why, however you did recommend further evaluation for another issue.
What does your states SOP require you report on?
Reporting on the data tag would be beyond the SOP. Just politely say that is not something you report on.
Now you might want to add a new comment to your template for IF this every comes up again.
I inspected a water heater last week that looked to probably be 45 years old. I did not see a data tag, but there might have been one on the back side, it was not readily accessible if there was one.
Bingo.
Moving forward, I would note if the data plate is one of the following: not accessible, not present or not legible.
No, and you do not even have to report on the age of the unit or anything in a home! In my company we do report items that are at the end of their expected life or useful life or that X is in the last third of its expected life..
Thank you all! He was just looking for someone to blame and the plumber told him that “your home inspector is required to tell you this”. SMH. But I really appreciate you guys clarifying this for me. I didn’t think I was at fault and am glad to know I’m not!
The data tag is always used to research the serial number to determine the Date of manufacture. If the data tag is missing, there should be a comment, letting the client know that the data tag was either illegible or was missing and for that reason you were unable to research the serial number to determine the age of the unit. Also, any condition rating that say unknown should follow up With a comment stating the reason why it is unknown. Example, if you are unable to view a receptacle behind a washer to determine if it is GFCI protected, and you put your condition rating as unknown for GFCI protected, your comment should state why…
Here is an older thread going more into missing data plates on water heaters,
