This feeds a 220v 50 amp gfi breaker in a subpanel for the master bathroom spa., then the wire size going from the 50 amp breaker in the sub drops down to 14 guage going to the spa motor. but i am sure that there was a permit pulled, somewhere
Originally Posted By: Jason Reed This post was automatically imported from our archived forum.
Are you certain this is feeding a 220 panel? It looks like the feeders are hooked to the same leg of the main, being hooked to the same ‘tongue’ on the bus.
As long as the 20 amp breaker doesn't have any 14 awg hooked to it, and the circuits indeed are being used as 2 separate 120 volt circuits (each with its own dedicated neutral) then it'd be fine I think.
My guess is one circuit (probably the 15 amp) runs the jet motor and the other 20 amp runs the heater.
Originally Posted By: kdolin This post was automatically imported from our archived forum.
Good point on the breakers being on the same leg. I did not put a meter on it but traced the two lines into the same conduit and the lines coming into the sub were the same size and appeared the same age.
But the problem with that install is there is no neutral line. in the circuit.
Regardless of what the final is, you must agree its a hokie installation and derserving of a flag and “further diagnosis by a specialist” required.
