So is there an issue?
Kinda boring actually. What’s so interesting?
I guess the question is; " Is that a condensate discharge and does a dishwasher drain hose qualify for a condensate discharge drain pipe?"
Time will tell I suppose.
Yes that is the condensate drain line. It appears to be a Rinnai tankless water heater. The condensate drain pipe description is in the installation manual. The OP can figure it out. He’s MIA.
Did I read something in there about plastic hose
Are we ignoring the pressure relief valve discharge piping?
What about it Ryan?
All those reducing elbows/fittings?
I don’t know if this is a new house or an old house but that insert fitting was acceptable in the IRC prior to the 2018 book.
That looks like a reduction straight from the TPRV to the pex. Is it ok?
That’s a 3/4” PEX fitting so prior to 2018 yes.
Maybe we just can’t see it, but a gas valve prior to the sediment trap would also be nice.
You’ll have to get with the local AHJ to see if a 3/4” PEX fitting (approved fitting prior to 2018) is restricting a 3/4” valve at the time of installation.
Cant report on what I can’t see. The elbow is blocking the view of where a gas valve is normally located.
Drip Leg…?
Here we go
We call em “drip sediment trap legs” in these parts.
