Any advise on inspecting a moblie home?
look for water leaks under the home…
Check out the insulation wrap in the undercarriage and tie downs.
Check for possible PB pipiping
Check for soft flooring around the perimeter walls and in the bathroom.
Check roof condition
Everything else pretty much a regular inspection
Probe under all windows and doors because that is one of the places you will find water leaks or past water leaks.
Take this course here for further assistance;
https://www.nachi.org/manufactured-mobile-homes-course.htm
I am doing the class currently
You can tour the crawlspace of a mobile home with a 360 video I recorded. https://youtu.be/VpCIf0diE8I
If you are doing a mobile home, do the MFD Cert too: https://fullviewdigital.com/mfd-certifications-add-weekly-bottom-line/
