I just signed up to take my certification courses and currently have a old laptop. I will be purchasing a new one for the business when I’m finished. Any suggestions for a good one?
I’m running a 3 year old MacBook Pro w/the M1 chip and it very fast. And, they now have a M4 chip.
Very happy with my laptop.
Get at least the M1 or M2 chip anything before that is noticeably slower.
Apple has refurbished ones available:
I bought an HP Elitebook 8770w refurbished from a local repair shop 7 or 8 years ago, I was pleased with the unit. After that I bought 2 more because they were so cheap (<$400). 2 get used daily, I keep one as a backup (because every time a computer issues arises it is at the start of a long weekend, when you have a report to finish).
I was thinking of the Mackbook Pro. Bought one for my Daughter’s college classes and she loved hers. Thanks for your response!
I’ve heard of the Elitebook. I will put that on my list of ones to check out. Thanks
Just make sure get get one that will sync with all your other devices that you use for inspecting,ie, phone, tablet etc…
Excellent point
. You don’t want to be fighting the whole apple/android connectivity thing…![]()
You also want a decent processor and more memory than you think you will need. Most package deals anymore will have a killer processor and/or a large HD or SSD, but wont have squat for RAM…
I have owned many (prolly six) Laptops over the decades.
My faves were an Acer and HP Pro & Elitebook. Worst was a Dell!
The number one failure I went through on most every single one of them, was a crashed Hard Drive!
The only exception were the ones I converted to SSD Drives. Now that SSD’s are common pre-installed in Laptops, that is my single most requirement. If I purchase one without the SSD, I convert it over while still new. This is especially true if a refurb unit as most refurbs use ‘wiped’ drives that typically fail in year one!!
Do a little research to find out what Hunter Biden was using and don’t use that brand. Apparently that brand fails at the most inopportune time!
In all seriousness you should be specifying what you will be using it for (not just “for the business”) and then move from there in the selection process. For example if you plan to do the oh so popular on site reporting most likely you won’t be needing it for report writing. From there if all you will be doing is simple business tasks then an inexpensive and reliable machine may be all you need and your current machine may work well.
If you will be moving past simple business tasks you need to know that as you might need a much more powerful and fast machine. Obviously that would be dictated by the software you plan to run as well as any companion hardware you may be connecting to it which may also dictate the operating system you run.
Thanks for all the suggestions and input.
Avoid Windows 11, if possible. Lots went haywire when I stupidly bit on the update. I may go through the painful process of upgrading (you read that right) to Windows 7, or even XP, if feasible.
I attempted to go to a Mac, but found the filing system atrocious, with only icons of pics without visible file names, unable to make folders for resized pics, and therefore unable to tell resized from full size pics, which is obviously not good for editing reports or emailing pics.
Just out of curiosity, which Mac did you try?
Still using 7 and XP on 3 computers, I refuse updates when ever possible. This newer HP has 10 installed, glad I have refused the update to 11 after reading your post. I tried a MacBook right before I bought the 3 HP’s. I didn’t like it for my daily needs.
I went through two HP laptops in a four-year span. The hinges broke away from the case on both of them. I now have a Samsung that I have been really happy with.
For what those Samsung Galaxy’s cost, you damned well better be happy with it!!
Avoid Winders if at all possible! If you can’t then try to do what Frank and Dave have done by using older versions of Winders. I have a computer running Winders Vista that never sees the internet. The only reason I have it are two applications that the vendors refuse to port to LINUX and LINUX’s WINE emulator (Winders emulator) really is no good. Otherwise I would not even have that Winders based computer.
First off so you know where I am coming from I started with Winders 2.1 and was a major command line operator! I have been a Microsoft Certified System Engineer (MCSE) and after getting into UNIX/LINUX wondered why I ever went the Winders path!
If you run Winders on a computer, especially after Winders XP, you become locked into them until your computer dies! Starting with Vista even the computer suppliers who pre-loaded Winders refused to issue the Operating System (OS) CD’s so you could reload it if ever needed. I had to fight Dell for a copy (stay the hell away from them!!). Now not only are you forced into continual update after update to handle their screwed up software changes it appears now you have to reload from the network instead of controlling it locally with a CD. Also even with the CD a reload would take hours upon hours just to reload the OS and then you had to set it all up again not only with what little OS settings you have but also any software you might use.
Winders finally evolved to the point where Microsoft, along with the hardware manufacturers, appeared to purposefully control the lifespan of the hardware and that lifespan tended to be short forcing you not only to upgrade your hardware but also to the later Winders OS.
I switched to LINUX about 20 years ago and never looked back!! LINUX has evolved so much that even if you’re not a Tech person it is similar to operate (very good graphical user interfaces), way safer against hacking, and so many other advantages as well. Oh and did I mention that it is FREE! Of course I did not and Microscrew won’t! Oh and did I mention that all of the software you would need to run a basic business is FREE? Of course not and neither will Microscrew!
I recommend everyone move to LINUX and this is a simple way to do it.
- For all of you who do on site reporting you are most likely running your program on your phone so you do not need Winders! If you have to run on your computer any vendor’s program components for reporting then make sure they have ported that function to LINUX or use some other Vendor’s program. Anything you need to save to your own computer you should be able to do it by networking the phone with the computer or accessing their system with a browser.
- Look at any other special program or service you feel you need to run for your business and determine if it has been ported to LINUX or you can access it online with a browser. If not then find another service provider or program where you can do this.
- If you use Microscrew Orifice for your spreadsheets, correspondence, etc., don’t worry since LibreOffice (the newer version of Open Office) is completely free, fully functional, way more stable and capable than Microscrew Orifice. In the context of operating it is so much like Orifice you almost won’t notice the difference.
- Do you use photo editors, photo compression tools, etc., etc., on your local computer? Not to worry as there are so many different ones available for LINUX and they are FREE!
- Do you need a new and faster computer to run LINUX? NOPE! LINUX is designed to run on older machines and make them run faster! You might lose some graphics capabilities or other smaller capabilities that are not needed for the business but who cares! Most of that is for gaming and even with newer hardware many game manufacturers have ported to LINUX and those that have not are typically available online anyhow. You can play your games on your 60" TV instead!
I can go on and on but will end with a little history of running LINUX for nearly if not 20 years.
- I have never been hacked and you know when you’re being hacked! Even if you are (rare and very, highly unlikely) LINUX is designed to handle it extremely well. They will not make it past your assigned user space and into the OS like they do with Winders! LINUX will shut it down quickly and recovery actions on your part are extremely easy and fast.
- The only time my computer slows down (not on the internet but the computer) is with a program that wasn’t quite up to par. Since LINUX and all programs you load are Open Source (anyone can obtain the code) their are so many LINUX Gurus out there writing corrections so fast it makes your head spin! Microscrew takes forever to write corrections and when they do they typically screw something else up in the process.
- Only had to (by necessity) reload the computer twice and both were storm related and I had little choice but to run it as reports were due. Once the system was scrambled and the other lightning took out the whole computer. I have two laptops just for this reason. It took less than 1.25 hours to completely reload the computer and download all updates and then another 30 minutes to quickly reconfigure programs I use for reporting. With Winders the last time I had to reload it took 6 hours just to reload the OS.
- Tried my hand at a BETA release of a new LINUX version once (the absolute last time!) which had some annoying but not show stopping problems with it. The release took about 45 minutes to upgrade and another about an hour to fall back to the past release. The BETA release issues were quickly corrected and when it was released as a stable version it was a nice upgrade!!
Move to LINUX and once you get used to the small differences you’ll wonder why you ever stayed with Winders! BTW LINUX has been ported to MAC for a long time. Also for you that want to run Winders still LINUX does have a dual boot installation option where you can load both and select either when booting up. Use caution with the dual boot though since Microscrew has been on to that a long time and if you don’t load it right Winders will screw up the entire computer!
Having been in Tech since the 80s, I can tell you from first hand experience that Linux is quite capable of being hacked. No, the base OS isn’t typically the issue, it’s all the things you have to layer on there and build into the kernel that are the problem.
Before the days when every router came with NAT, I used a Red Hat box to do that for me at home. For the uninitiated, NAT is network address translation. This means the server has one IP address for the internet(WAN) NIC and connects to the LAN (your computer) on a different NIC. Every router that you buy these days does this, but back in the 90s, they didn’t exist. I had a giant tower doing what your little “internet box” does now.
My Linux box was sitting there fat and happy for quite some time, I’m going to say at least two years. I had patched it a few times, but other than than, no issues, great uptime.
I started hearing the hard drive go “thump, thump, thump” rhythmically every few seconds. I figured it was dying, so I made a backup of it and waited for the inevitable.
About 2 weeks later, I got a call from my ISP. “Your computer had made entries into several Wall Street financial firms, we are literally disabling your internet access”. And they did.
I told them my configuration, and they sent out a tech who knew nothing about Linux. I was able to find where the hacker got in and how he’d given himself permission. A full root job.
By that time, Linksys had a basic NAT router out, so I bought it. I’ve run some powerful Linux firewalls at work, and it’s great. As far as a normie getting under the hood though, forget it. It’s still too complicated.
Something not mentioned here (maybe I’m showing my lack of technical savvy) get a solid state hard drive. Mechanical hard drives will crash for no reason and are expensive to recover. Also get a backup system to store your business data (external hard drive hooked to your LAN).
Omg you guys are funny
