I want to purchase a RILEM tube, for measuring masorny wall porousity, but can’t find any place that sells them.
Anyone have any sources?
Thanks. Tried there, before, but the link didn’t work. Yours did.
With all the split block around here, that might be a good tool to have.
As well as generally, for masonry inspections.
Look at this picture. New brick veneer house.
Note the efflorescence pattern around the door and window.
Proper flashing above both, BUT, the lintel / stone interface was sealed with caulk.
The result? Interior water flowing over the end dams of the flashing and running down the wall on the door and window side. The water source was from the gap between the balcony stone and the stone wall. Water, just pouring down behind the wall, getting stopped by the flashing, but over running the flashing because it had no place to go.
BTW: There were weep wicks, but they were caulked shut as well.
When will they ever learn.
Coulkd swear I see wicks in the picture but must be the white caulk.
Also almost looks like a see a line of rust along the lintel edge.
Source was a gap under the concrete coping at the balcony Will?
I take it there was no moisture barrier under the coping.
There were weep wicks, but weep wicks alone are not sufficient to drain out standing water. Weep wicks should extend about 1’ up in the wall and wick out moisture. The open lintel / brick (or in this case, stone) interface allows the water to drain from the flashing AND allows for ventilation.
No flashing under the coping, but also an open area (see attached picture) and also note the staining on the coping with the efflorescence below.
Hope this helps;
Hey Will, Is there a tool you DON’T have?
Just rge ones I need to do the job.
It’s not what tools you have, it’s how you use them
Looks like that guardrail is cracking the concrete.
Thanks, Ken.
With regards to the water problems we have been having with masonry buildings around here, here is a great picture that I took, in passing, on my way to an inspection, yesterday.
Typical problems:
Go figure. The picture says it all. A 2 1/2 year old condo building.
H
Sorry, I gotta ask. How can you tell all that from a picture taken from 50 feet away?
I cheat :mrgreen:
I knew I’d wriggle the truth out of you.:mrgreen:
Here are companies that sell RILEM tubes (i.e. testing kits and accessories).
kit.https://m-testco.com/rilem-tube-kit/
https://ktagage.com/product/rilem-tubes/
Thanks,
Frank
