Originally Posted By: Joey D’Adamo
Are apartment buildings allowed to have branch circuits which span multiple apartments?
Originally Posted By: jmcginnis
Originally Posted By: bbadger
Quote: |
210.25 Common Area Branch Circuits.
Branch circuits in dwelling units shall supply only loads within that dwelling unit or loads associated only with that dwelling unit. Branch circuits required for the purpose of lighting, central alarm, signal, communications, or other needs for public or common areas of a two-family or multifamily dwelling shall not be supplied from equipment that supplies an individual dwelling unit. |
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Bob Badger
Moderator at ECN
jmcginnis wrote: |
Joey...
What do you mean by "span"? Do you mean to pass through one apartment to get to another or do you mean a circuit that is shared by 2 or more apartments? Or do you mean something else? |
Originally Posted By: jpeck
jmcginnis wrote: |
" Branch circuits in dwelling units shall supply only loads within that dwelling unit or loads associated only with that dwelling unit." |
Jerry Peck
South Florida
jmcginnis wrote: |
Jerry...
EXACTLY! So now it becomes necessary to define the word "in" in the phrase "Branch circuits in dwelling units". That might seem like a simple task but then again maybe not... for example, in some condo documents... the part of the condo belonging to the condo owner starts at the drywall on the walls and ceilings and the flooring material on the floor.... everything outside of that, including the framing members is considered "common areas" and the responsibility of the condo association... therefore, could the circuits then be run in the framing members (since technically they are not part of any one condo) regardless of which units the circuits serve? |
Jerry Peck
South Florida
