Arc Fault Breakers
Originally Posted By: anatol polillo
Fellow Inspectors,
Do Arc Rault breakers typicaly make a slight buzzing sound? I had 3 in a new panel yesterday and they all were making a small amount of noise.
Anatol
Originally Posted By: Vince Santos
This is what I have come up with:
Some buzzing is considered normal when using an AFI breaker however it is more common when they are installed with solar power and non-sinusoidal current waveforms. It will not cause any problems with the operation of the breaker or the system.
Here is more information about AFCI's
http://ecatalog.squared.com/pubs/Circuit%20Protection/Miniature%20Circuit%20Breakers/0760DB0201R1102.pdf
Desire is half of life, indifference is half of death.
--Kahlil Gibran
Originally Posted By: rray
I’ve only found AFCI breakers in two houses so far, and all of them were buzzing. I discussed the AFCI breakers with my Clients and told them that I was unfamiliar with whether or not they should buzz but that I would find out what I could about them. Didn’t find anything.
Home inspections. . . .
One home at a time.
Forget AFCI, no Square D breaker should ever ‘hum’.
I have only seen three Square D breakers that were bad.
1) a 60 amp A/C breaker 'hummed' before it tripped. The c-750 was to tight.(1993)
2) the breaker would NOT turn back on. A good thing.(2003)
3) a humming breaker. Last week on a 1 year old home.This was deferred to the originsl EC. I do not know the reason yet.(2004)
Mike P.
