Are additional rafter ties needed here?
Ceiling joists are running perpendicular to the rafters. A couple rafter ties were added but I believe additional ones are needed. Thoughts?
Not near enough info for someone online viewing your one single picture to determine if more ties are needed. But if you believe more are needed, go ahead and suggest that. More can’t hurt, lol.
What I can determine from one single photo of approximately1/3 of a roof plane at the gable end: This is an old home. There is more weight due to the added plywood atop the planks. The pitch is steep. The insulation is sparse.
What could more rafter ties accomplish? After 80 years don’t you think the roof design proved itself?
The insulation is lacking…
Following on Bob’s comment, do you see evidence of any failures? Do you see evidence of removed ties? You’re paying attention so that is great, but be careful about crossing the “over thinking it” line. Particularly, with older structures, we see many things that would be done differently today but are performing.
that is a great phrase to insert into a report in a situation such as this…
