Article on double taps
I used to have a nice article with pictures that showed different types of breaker styles and which ones allowed double taps. I do not recall who published or wrote it. I can not find it in my files and would appreciate it if anyone has a copy. Thank you for your help.
This is one the you are looking for
Thank you Juan, This very similar to the one I had. The one I want is not published by a home inspector specifically but was a PDF I believe with some additional pictures attached. Yours is helpful and thank you again.
