What can I use to match asbestos siding? I need to replace some boards.
You can usually find cement based siding at a lumber yard but you are kind of limited on styles.the box stores wont carry it
I’m not sure where your located but here in the Reno, NV area we have lots of this siding. Often when people replace the siding they will put the extras on Craigslist. You can also check http://www.gaf-weatherside.com/?gclid=CKL4r4qVkasCFewaQgodSykvxA check your size since I know of two different sizes here. If you have to cut the old siding don’t use a saw. You can try to score and snap. The original installers used something like a paper cutter. They rent similar tools for flooring. Holes for nails were done using a punch. The new replacement shingles don’t have the asbestos so follow the manufactures instructions.
