Ha — fair point Scot, I appreciate the heads up. To be clear, the tool itself is association-agnostic. Works the same whether you’re InterNACHI, ASHI, state-licensed only, or independent. The ASHI listing just happened to come through first so I mentioned it for transparency.
The real value is the reporting workflow itself — cuts septic report documentation time significantly and standardizes the output for counties and state officials who are picky about format. Happy to run a demo report if you want to kick the tires.
Yes this is solely for Septic. We believe in quality products were the AI is trained in specific field rather than a general inspection AI. The septic AI has been trained on over 10,000 hours of in field data making it extremely accurate when using.
