Atain v Basement waterproofing specialist
… 'Inspected the property and advised (lollloll) a NEW french drain system would need to be installed…
$16,000
…there was a rainstorm the evening of day job was completed, homeowner n wife inspect property next day n find flooding along front wall n other areas AND find extensive fracturing and bowing of front wall that was repaired (pffft) and reinforced
Engineer comes out n says, 'French drain system would not be sufficient to prevent the water issues affecting the property and that the work should have been done on the outside.
They needed an engineer to inform them of this? lolllll smgdh
Beatles, ‘the long and winding road’
Sounds like Basement Inc didn’t understand that general liability insurance doesn’t cover their “errors”.
see the big boy root here? And see the exterior cracks etc near end of video in block basement wall.
Installing any interior drainage system doesn’t remove, reduce any lateral soil pressure or possible roots and they do not ever waterproof any of the exterior cracks in these walls hence they do NOT stop water from entering, they at best can only hope their fraudulent system diverts the incoming water.
Lateral soil pressure, clay soil does cause many of these EXT cracks in basement walls, and bowing, and sometimes roots cause cracks n subsequent leaky basements but these INT system jerks continue to bs people, as in storey above, and tell them all they need is an INT drainage system that oftn costs MORE than exterior waterproofing would cost = incompetent idiots or total frauds
from yesterday, went to Buckeye-land, homeowners were lied to by Everdry, sure were.
