Attic support question if I remove 2x4 web structures
I would like to get professional opinion on a proposed project I have in mind. Need to free up space in my attic over garage. The roof has about a 6/12 pitched and about 16’x 12’ that I’m looking to free up. Ive included a drawing showing current construction and proposed. If I remove #2,#3 and , #4. 2x4’s ( currently every 16-20”) would the roof be adequately supported if I put say one 6”x6” post in middle or do I even need a post.Thanks
Marc
You know what we do as home inspectors when we see a field modified engineered roof system? We call for evaluation by a structural engineer.
I’ll make the same recommendation here. We do not recommend modifying engineered systems without a structural engineered design or approval. There are some very good reasons for this.
Ask a professional structural engineer. Free advise is worth what you pay for it!
Really good question. In my experience, modifying a truss without the help of a structural engineer is not a good idea. When you remove the diagonal members, like you are proposing, you take away the truss’ ability to carry load as intended. Substituting a vertical member, just won’t help like having the diagonal members that were replaced.
Just curious, what are you trying to make room for?
At least 2 things you haven’t considered / included. Roofs built with conventional rafter and ridge construction have larger dimensional lumber. No mention of snow load. Always a consideration in some areas.
As said above, you need a Structural Engineer who can consider ALL the specific needs of your project.
The alternative is the roof crushing your new car below when it fails.
The best way to get a qualified answer to your question would be to hire a Structural Engineer. A truss system is an engineered system, and only a Structural Engineer or the Truss Manufacturer are qualified to give you a good answer to your question.
When a truss gets modified, load calculations must be worked out so the load support lost from a modification properly gets transferred to other areas.
You ca not remove those members. Engineered trusses are designed as a complete system and every member has a function. If you took those out the roof would be on the garage floor.
Trusses are engineered components and shouldn’t be modified without signed and stamped instructions from an engineer.
Any modification or repair must be designed or approved by a structural engineer or the original truss manufacturer (or their engineering team). “DIY” modifications/repairs can lead to progressive failure, roof sag, or collapse under load.
The prescribed method for repair generally involves an architect or engineer to evaluate and draw up a prescriptive method for repair and sign and stamp the document. A qualified contractor then should perform repairs per the engineer’s specifications, then post the signed and stamped instructions near the repair for future inspections.
I recommend that you get quotes for engineered repair plans and a local carpenter before attempting any renovation project. These plans should take into account the proposed loading of your new project (what do you plan to store or install up there?). For example if you plan to install an engine hoist, you are not only changing the structure of the truss, you are changing the loading on the truss.
Critical disclaimer: There is no universal “typical” repair—each truss is engineered uniquely (profile, spans, loads, member sizes/forces vary). Repairs must be designed or approved by a qualified structural engineer, the original truss manufacturer (e.g., Tindell’s, MiTek, Alpine/ITT, etc.), or their engineering team. Unauthorized fixes risk progressive failure, roof sag, or collapse. Industry standards (ANSI/TPI 1, SBCA BCSI guidelines) prohibit cutting/notching/modifying/repairing trusses without proper engineering.
Morning, Mark. Pleasure to meet you. Welcome to the InterNACHI message board community.
Mark… You modified roof trusses. A no no. You removed struts and posts.
In my opinion, installing roof rafters would be a workaround. A licensed carpenter should be able to assist you.
