Older home with auxiliary panel in out building. Can someone review and let me know about wiring on hot lug? Haven’t seen this before.
Also, any additional comments about the panel would be appreciated.
Thanks
Improper 3-phase bootleg wiring. Lug at top right is not rated for multiple conductors. The center breaker is improperly wired. Defer to an electrician for repairs.
The entire panel is wired wrong - that’s really all that needs to be said.
…also double tapped breaker and neutral is improperly bonded to ground (assuming this is not a main service panel)
Glad to see your input Jeff… Hope all is well!
Super busy at the new house, but all is well - Thanks. I hope you fared well with the storms in your area.
