Originally Posted By: rfoster1 This post was automatically imported from our archived forum.
Professional Equipment has a 24" awl with a wood handle. I think they want $25 for it. I use it in every crawlspace. Great for spider webs (and for beating back the rabid rodents). Can also reach some otherwise out of reach soffits, etc.
Originally Posted By: dedwards This post was automatically imported from our archived forum.
I went to the flea market and bought a 18 inch phillips head screwdriver and ground the tip into a blunt point. I also used Carla idea for the extending handle only mine is aluminum with plastic grips. I use it with a heavy duty plastic spring clamp to hold onto a two pin probe for a moisture meter too with an extention cord from Radio Shack to reach those water stains on the tall ceilings. Saves me scads of time and I don’t have to pull out the ladder each and every time. Im basically always looking for ways to demonstrate laziness.
Originally Posted By: dnice This post was automatically imported from our archived forum.
I also use an extendable paint roller pole but I cut the screw on end off a paint roller and ground the handle of a nice awl to match the roller handle in diameter. I epoxied the awl to the handle and wrapped it with black tape. It looks neat and clean and not Mickey Moused. I keep the awl unscrewed (and with a plastic cap on the tip) and in a pouch until I need it.
Originally Posted By: sspradling This post was automatically imported from our archived forum.
I went to Walmart and got a hotdog fork in the camping section, about 3 feet long with a wood handle. Ground the fork off, leaving a nice sharp point. It’ll reach most soffit and fascia, reach down next to deck posts, pry vegitation away from siding and foundations, and fit alongside my flashlight in the belt ring. Be careful not to impale yourself if hopping off retaining walls or squatting next to a/c units.
Originally Posted By: psisler This post was automatically imported from our archived forum.
I made my own awl that was constructed of a 24 inch threaded rod and a handle that accepted the threaded rod for $4.25 at the local hardware store. I ground down one end of the rod and screwed it into the handle and had a 2 foot awl for $4.25 instead of $25.00. Works like a charm on those hard to reach places. Just my nickel.
