Originally Posted By: rpalac
Just to add a little fuel to the fire here…
Is it okay to feed throu a recepticle to use it to go to the next, or do you have to pig tail it.
Then why are there two screws?
Gee, If it has two screws that clamp two wire each and a set of holes for back wire can I place 4 or maybe even 6 on each side and be leagal. Hell thats more than the cu. in. of the box is rated for just on one side.
Well then again that configuration of two blades without the littl notch in the center means it is a 15 amp. receptical. Can I use 12 wire to feed it or is it over rating the device?
Okay.....now fight nice guy's.
Bob P.
