Balcony or Window ?
As if inspecting is not tough enough ,you gotta decide which heading to put this contraption under.
Is it a window or a balcony?
http://www.youtube.com/user/HofmanDujardin
Here is a warehouse view…http://www.youtube.com/user/HofmanDujardin#play/all/uploads-all/1/0X_i-kjoyuY
Manufactured ,so I assume they are safe…:shock:
That’s pretty sweet. I would like to walk out on one and test it out.
Man the structure support needed must be massive. Somehow i doubt wood frame could handle it, The factory view shows steel H beams.
I know you knew,Bob. Just thought I would post it, just in case! :wink:
Notice how the floor is glass making me wonder if that tempered glass can crack through easily.
Sears Tower just put in a retractable balcony last month though I am not sure it was the same designer.
The one at Sears supposedly will not shatter and is some insane thickness.
I’d call it a baldow or a wincony.:stuck_out_tongue:
How about Porta-balc
I’d call it disclaimed!
