Basalt Rebar FYI
**Just came across this and thought I would post
Basalt Rebar – the alternative to steel and fiberglass
Basalt Rebar reinforcement is an alternative to steel and fiberglass for reinforcing concrete
Made from volcanic rock basalt rebar is tough, stronger than steel and has a higher tensile strength.
Much lighter than steel, 89% percent in fact! One man can easily lift a 100 meter / 328 foot coil of 10 mm basalt rebar.
Basalt rebar is naturally resistant to alkali, rust and acids. Moisture penetration from concrete does not spall. Needs no special coating like fiberglass rods.
Basalt rebar has the same thermal coefficient expansion as concrete!
Allowing thinner, lighter panels and decks, basalt rebar reduces the thickness and spacing between the rods and the concrete and surface. Much more flexible design! Smaller rods allow for more critical spacing and designs.
Basalt rebar is easily cut to length with regular tools.
Basalt rebar does not conduct electricity or induce fields when exposed to RF energy, great for MRI or data buildings.
Basalt rebar is perfect for Marine enviroments and Chemical plants where corrosion is a continuous concern.
LINK TO BASALT REBAR ACI CODE INFORMATION
Basalt Rebar is available in the following diameters: 4mm. 6mm. 8mm. 10mm. 12mm. 25mm. 4mm to 12mm available in 100m coils or cut lengths. 14mm to 25mm packaged in 3 meter cut lengths. Contact Nick for more information, basalt product prices and shipping quotes.
