Dumb, stupid, incompetent bulshtt…period!
Says, an INEXPENSIVE way to get rid of the water. Says there’s driveway outside…most economical fix??? #-o
Says who? B Dry or Hydroflo or the other 500+ inside system idiots? CMON!
Yeah, its letting water in…can you say mold behind that dumbaz paneling they put on?
And what about the possibility that a driveway/concrete slab can CAUSE these cracks in the basements walls, just leave them there…against the wall to cause further damage?
Or an underground root or expansive soil, just leave the likely causes of cracks or the WIDENING of cracks in the future, just let it happen eh, leave the shtt on the outside huh? ](,)](,)](,)](,)](*,)
The cost of that basement dewatering crap was very likely, at least, $1,200.
VERSUS, hand digging that area out and waterproofing it correctly…says it was about 4’ each way, so 8’ or so…cost for exterior waterproofing is right there…around $1,100 to $1,200!!!
EXPENSIVE? And if there’s a slab in the way/against the one side of wall then you saw cut a 18" wide piece out which I would NOT recommend they replace
Economical, inexpensive, that’s just more bulshtt, period!
Blurry/Puddle of Mudd …everything’s so BLURRRRRRY every inside system’s so fake
