Basic Electrician's Examination
Basic Electrician Examination
You Will Enjoy This. Very Funny... ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Fill in the Blank
What color is a green ground screw? __________.
Home inspectors are known as _____________.
We all know that in winter months, that if you walk barefooted a lot across the carpet, that electricity is stored in your fingertips. _____
If you do not touch another person or something metallic and release this electricity within a certain time frame based on your height and weight, will your fingertips blow off? _____
If you have a 240 v 7.5 HP 3 Phase motor that is 500' away from the panel, what size umbilical cord is required to start this motor? _____
Whenever you unplug something from the wall outlet real fast, the
electricity that didn't make it back into the wall outlet is stored for how long in the appliance cord? _____
True / False
Electricity will leak out of pipes if they are not connected with rain tight fittings. _____
To trip a circuit breaker, you must stick your foot out as it walks by. _____
When dealing with conduit, the O.D. must exceed the I.O. or the hole will be on the outside. _____
A keyless fixture cannot be unlocked. _____
A circuit breaker reads "20" on the handle. This means it can only trip 20 times before it is worn out. _____
If you plug something 110 volts into a 120 volt outlet, 10 volts will leak out and make a mess. _____
The gage of wire tells you how many plugs you can hook to it. _____
When hooking up a 200 volt heater, you must use 220 volt wire. _____
When pulling two 4/0 wires into a 1/2" PVC conduit, the PVC stands for "Pipe Very Crowded." _____
A flush mount device may only be hooked up to a toilet. _____
Service Entrance Conductors purchased from an electrical parts house with current already in them are very dangerous to install. _____
High voltage wire is used in the upper levels of tall buildings whereas low voltage wire is usually found in basements or underground. _____
If you have a molded case circuit breaker, the mold can be washed off with warm soapy water. _____
When landing a conductor runway light's are needed. _____
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: gbeaumont
Joe T wrote:
When dealing with conduit, the O.D. must exceed the I.D. or the hole will be on the outside. _____
I love that logic, too funny ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
