Bath tub window / fall protection specifically
2014 townhome inspection today. I’ve looked for similar posts but couldn’t find any that I felt addressed my concern specifically for fall protection concerns.
Master bath on the 3rd floor has a tub with a window that I feel has a safety concern. When I stepped into the tub to test/open the window, I could imagine myself falling backwards and out the window if the window was open with only the screen as fall protection. I felt my stomach drop thinking about it.
I’m asking as a refresher to make sure I’m staying in my lane. Do you or would you include this in your report as a fall protection concern/defect in your report? I also double check myself with ChatGPT (and other search engines) often and I’ll post what I got on this issue which confirms my feeling. Code is not my concern, just safety. Also, is the tub rim in my pics really considered the walking surface that needs a window sill height 24" above it for safety? It WOULD ALIGN with my gut feeling.
First the pics, then the Chat GPT answer:
Absolutely.
Not sure about “defect”, but certainly a potential safety hazard.
First.
I would have no problem reporting this with or without code support. My narrative would not mention inches or walking surface, but rather a low sill without fall protection, keeping it simple.
Thanks guys! :+1: Sometimes I just need to check myself. And there will be no decimals, inches, or walking surface mentions in my report per my own standards on this one :smiley:
Realistically, anyone that fell would likely just hit the sill and fall back into the tub but I agree it’s not the greatest setup. With things like this I just try to convey my opinion to the buyer to make them aware, and maybe write up something about considering restricting the window from opening for safety. I really see this two ways - liability (of course) and just being a good human and sharing my thoughts with the client.
I’d document it as a safety concern David.
Was the glass tempered?
The glass was frosted and I didn’t observe any markings.
IRC: R308.4.5
Safety Glazing (Tempered Glass): Any window with a bottom exposed edge less than 60 inches (1524 mm) above a standing surface ‘the shower floor’ and within 60 inches (1524 mm) horizontally of the water’s edge must be tempered safety glass.
Hope that helps.
Sorry to go off thread. Poor GFCI Placement. Ideal placement is 1 to 3 feet to the side of the sink.
The receptacle appears to meet the requirement that at least one receptacle is within 36” of the sink basin. Move it 12” to the right and it will be in the disallowed “tub zone”. The placement would have been acceptable in a 2014 build.
I believe the “walking surface” citation has to do with a tub sunken into a deck (you stand on the rim to lower yourself into the tub) NOT a tub that stands above the floor like this one.
Your narrative says the glass is frosted and tempered yet your reply to Ray indicates you saw no markings on the glass (safety glass will always have a safety marking).
I would be more concerned about the lack of safety glass. That sliding window can easily be limited to a smaller opening.
In my area: 9.7.5.4. Windows above the Second Storey
  1. Windows in public areas that extend to less than 1 m from the floor and are located above the Second Storey in buildings of residential occupancy shall be
a) protected by guards in accordance with Section 9.8., or
b) non-openable and designed to withstand the specified lateral loads for balcony guards as provided in Article 4.1.10.1.
It should be at least 1 foot from the sink but no more than 3 feet
Morning, Richard.
Hard call to make.
I only see one sink. It is a long vanity with one left side wash sink.
Moving the receptacle to the right of the sink would work.
I concur moving it, the GFCI outlet to the tub would be a conflict.
(A) Outlets within 6" feet of a water source should be GFCI. One outlet is required within 3" feet of a sink (measured from the edge of counter if a vanity, or from edge of the sink basin (if a pedestal sink.)
Side Note: a: Avoid placing outlets directly over the sink basin. Position them on the wall or side of the cabinet, but not more than 12 inches below the countertop.
b: positioned to the side of the sink rather than directly over it to prevent cords from hanging into the basin.
It’s not a hard call to make at all. There is no issue here.
Side note: I don’t get my information from The Spruce, whatever the f*** that is. I get it from reputable sources such as NEC or the National Kitchen and Bath Association(NKBA). Both of which just say that at least one receptacle has to be within 36” of the sink basin.
May I recommend you stop being vulgar.
As for The Spruce. If you ever come across an article that you think needs to be improved, please reach out by emailing [email protected].
The 36" inch rule is vague.
The outlet is clearly above a sink.
  • Location Distance: At least one GFCI-protected receptacle must be installed within 36 inches (3 feet) of the outside edge of each sink basin (lavatory).
“Fork” is vulgar?
I hadn’t written any narratives at this point. You might be referring to what ChatGPT wrote by evaluating the first photo.
it isn’t fuck either, it’s f***.
sure looks like it’s within 36” of the sink to me, but it does hang a tad over the sink, perhaps it would fall within the restricted area of the tub, but it definitely meets the sink requirements and falls within them. you were spot on that moving it to the right would have been better, but c’est la vie…
What the fork is going on?
We don’t want cords to hand down into the basin, I get it. But moving this receptacle 2 inches is going to substantially remove this risk? Nope. We can thank the NEC for the heads up but I would move along. Just my 2 cents.
FWIW, it may have been a bathroom remodel and the basin they picked out and loved was a hair too wide.
S**** for saying F***.
Read into it however you want, but that receptacle is within 36 inches of the outside edge of that basin. The code isn’t meant to establish a “no receptacle” zone. If it was it would say so.
Robert: The setup would not meet current standards, and it has nothing to do with the sink. Find that code and we’ll have a discussion. But it still doesn’t change the fact that in 2014, it was code compliant.
”The only thing worse than a home inspector that quotes code is a home inspector that misinterprets code.”
