Do you comment on bathroom vents that run through the eaves and discharge through the soffits?
Yes depending on specific conditions.
What comment would you make? I’ve only seen that a few times. They were working pretty well.
Not if the termination is on the exterior of the soffit, but I do write them up if they are terminated in the attic at the soffit.
My thinking is the humid air from the bathroom can get drawn up into the attic through the soffit vents. By no means is this as bad as the vent discharging directly into the attic.
It would be nice to see the soffit vents blocked off a few feet on each side of the exhaust termination. That’s the comment I’ve made on the few of these I’ve seen. Luckily it’s not a real common practice in my area.
That’s good thinking. Start with, do you see evidence of that happening? Mold in the attic? Moisture damage in the attic above a soffit vent? That sorta thing.
As I think out loud here…some considerations come to mind:
How close to the vent exhaust is the nearest soffit vent? They would need to be next to each other before I’d have a concern. So, assuming the vents are literally next to each other:
No evidence of a problem, but maybe the current owner never uses the bath vent fan. I guess you can write an essay about how a problem might develop with constant use of the bath vent fan during hot showers on dead calm days when it is cold.
How far down this rabbit hole would I go if there is no evidence of a problem? Not far.
Right through the soffit vent! I’m surprised that I haven’t seen anything in IRC about. Low risk but I wish builders would space it away from the soffit vent.
Thanks! So, why doesn’t InterNACHI put a comment on it? So, I am in the right in calling it a deficiency?
Where are you located? What year was it built?
Lon makes some good points.
Illinois, this year.
In my area… it’s a common short cut builders like to take to save a few bucks on the proper gooseneck vents with screen and backdraft damper on the roof, the FBC has requirements for it.
YMMV based on your local jurisdiction.
I would write it up, if it is blowing out hot moist air, in my part of the country in the winter time, that warm damp air is going to go right bad up into the attic.
InterNACHI is still saying that a mechanical vent cannot pass through a soffit to the outside, even though there was a big discussion about it a year ago. @bgromicko1
Because a home inspection is not a code compliance inspection. Are you “right?” If you see a performance problem, sure. A home inspection isn’t always right/wrong. Go get a job inspecting at a jurisdiction if that’s what you’re looking for. I’m not meaning to be a dick but all this code section citing and “right/wrong” (looking for some rule) has RUINED this profession. Right/wrong and codes are not the way home inspections are or were ever intended to be. We’re there to look at performance, not design and the almighty codes.
2018 ICC did add a 3 ft rule from gravity intakes openings and if less than 3 ft below mechanical intakes. but if built before that it was OK.
There are IRC rules about bath fan venting.
https://codes.iccsafe.org/content/IRC2018/chapter-15-exhaust-systems
