Be Safe when inspecting the electrical system
Hey Commercial Inspectors. Never open or touch a panel without verifying that it is safe first. I use a non-contact voltage detector every time. Are you?
Yes Sir. Yes Sir, I do.
That’s a good practice and I’m glad that you didn’t suggest using the back of your hand. Was the cover door opened by hand before you pulled out the tester?
