Yes I tested both the top and bottom. Also there were two other receptacles in the same circuit that tested test fine. It was just this one that did not.
Haha! I appreciate the article to learn!
This is our primary tester. We also have a three light and a proximity type.
Klein Tools RT310 AFCI and GFCI… https://www.amazon.com/dp/B07PMDRHXB?ref=ppx_pop_mob_ap_share
I don’t care for that tester simply because it uses batteries. Just another item to fail when you least expect it.
A solenoid tester is a better choice. If you can afford it an iDeal Sure test is another way to go.
Although I have an older Sure Test, both that and the Klein tester above are overkill for a Home Inspection. As HIs we are doing a visual non-invasive inspection, as you move away from that with specialized tools you can increase your client’s questions (expectations), your own errors and ultimately your liability.
Keep it Simple Stupid.
Your non contact tester tests for the magnetic field from electricity. It can be picking up power from a wire in the box a loose wire to the receptacle terminals and power that’s less then what your plug in tester will pick up. You need to get a better plug in tester, I use one that has a screen and will show power at any voltage, has a GFCI trip button and timer to show the time it took to trip it. They are way more useful than the simple 3 light testers. I have the one in the picture and another one with a cord that they don’t sell any more.
That makes sense. I appreciate it.
That one looks way nicer than mine. I’m thinking it might be time upgrade mine and get something that works better. I didn’t realize it, but I think mine is pretty crappy.
This is not true! There is no magnetic field without current flow (a closed circuit with a load). You need to read the Fluke article I posted above about capacitive coupling.
Skip it and buy a wiggy or Klein ET60 LoZ voltage tester. Those fancy looking plug in testers with the display are junk. They have a battery to go dead and they give misleading or confusing readings a lot. Do a search of the forum or Facebook to see what I mean. I bought one when they first showed up in HD and didn’t even use it for a week. The three light testers are certainly old and primitive but reliable for what they are.
Listen up.
I appreciate it. Because now I am definitely looking for a new tool. So I think that’s the way to go!
You need to start with the basics. A solenoid tester and how to use one. All you need to do is confirm proper wiring at the outlet.
This is fantastic.
That’s cool I guess. I don’t have time to stick a tester into each outlet three times. And with all the stuff I’m packing anyway a few extra batteries is no big deal for when I have to change the batteries every 70 or 80 inspections.
Many don’t have time to learn. They already know everything. You are not alone.
My point and I think what Bob is really driving at, is the battery powered tester doesn’t tell you anything particularly useful where as a low impedance tester like a wiggy does.
That klein looks cool to clients and realtors but adds little to no value. They are more likely to display confusing or erroneous readings than a traditional diode tester. It can show voltage and a time to trip for GFCIs. If you want voltage for some reason you can get that in a non battery powered model. The time to trip is well beyond our scope and frankly if you want to test for that use a better device and know the standards forwards and backwards first.
A low impedance tester is a very useful tool to have. I don’t use it in every outlet, that’s what the basic plug tester is for. The low impedance tester can check 240 receptacles, and help when a plug tester shows something “funny”. Understanding their use, even if you don’t carry one, is extremely helpful for understanding how household wiring works.
I have a pretty good understanding on how residential wiring works. I have a pretty good understanding about how commercial wiring works.
The device I use provides all the information that I need to do a proper home inspection and will fit in places where the little three light units sometimes won’t.
As for knowing everything… it’s a heavy burden.
