The dryer vent flap is improperly installed (upside down). The present condition can/will trap lint and create a potential fire hazard; Also will not allow the dryer to properly vent. This is a safety issue. Corrective repairs by a qualified person are recommended.
The dryer vent damper was improperly installed. This can cause venting problems and create unsafe conditions. I recommend having the dryer vent damper properly installed.
· Safety Issue, Repair: We found the dryer vent exterior wall damper damaged. It should be replaced to prevent outside air, insects, rodents and birds from entering the duct. Make certain the duct is metal and at least 10 cm (4 in) in diameter and as short and straight as possible. Seal all leaks. Screened type wall damper needs to be cleaned regularly as lint accumulation will restrict air flow resulting in possible fire.
mauger
(Mike Auger, CMI - RI 43685, RMC-142, RMB-096)
16
Dryer vent installed improperly. Current configuration is amateur/incorrect installation. In this configuration (flap unable to open) it creates a potential fire hazard, and at least prevents clothes dryer from properly, efficiently drying clothing. Recommendation: Install dryer vent to manufacturers specifications, so as to have the flap/louvers properly allow air to discharge, and still close when not in use.
