Best way to insulate basement walls?
We have a 60’s ranch … one story with full basement … front wall is an earth wall and one side wall is partial earth … front and back exterior walls are 8" block and side walls are 8" block with brick … front interior wall is exposed block and rear and side interior walls are finished with paneling on fur strips … we’re remodeling and getting into some of the interior walls … of course, there is no insulation, vapor barrier, concrete sealer, or anything else … what is the best way to build back the interior walls, with special regard to insulation, etc. … we’re going back with drywall … by the way, there are two baths in the basement with exterior walls.
Thanks in advance for your help!
Bill
What geographic region of the country is the house located?
We’re in NW Arkansas … zone 6a.
If you’re going to insulate from the interior, see www.buildingscience.com .
They promote the most sensible interior wall system.
Brian,
Any ideas about insulating a earth wall?
Cheers,
“front wall is an earth wall and one side wall is partial earth … front and back exterior walls are 8” block and side walls are 8" block with brick … front interior wall is exposed block and rear and side interior walls are finished with paneling on fur strip"
I thought he meant “buried in the earth”! need clarification!! Anyways, earth is an insulator, ain’t it?
Brain,
It maybe an insulator but it also allows water moisture through depending if its below or above and or protected?
Earth wall as in adobe or rammed earth wall?
Clarification …
our basement walls are all made of concrete block … the front wall (closest to the street and running parallel) is all underground and part of it is protected with a patio and carport at the street level … one side wall is partially underground and partially protected … because of the age of our house, I strongly suspect that there is no french drain below the footing of the front wall … probably, the only protection on the outside of the front wall is the black tar stuff … anyway, I’m trying to find the best way to insulate earth walls (walls with dirt against them) and non-earth walls (no dirt against them) … also, do any of the walls need vapor barrier, or should all of the walls just be allowed to breathe?
Bill, possibly a Z-girt anchored to your block walls with a 2" styrofoam for an R-10 value and a drywall to cover it up to meet the fire codes might work for you. A vapor barrier would not be necessary with the use of the styrofoam.
This is assumming you have a dry basement.
The IRC appears to call for r-10 for your area , for basement walls.
Marcel :slight_smile:
Go to: www.buildingscience.com and see their recommendations.
Brian; do you mean this?
http://www.buildingscience.com/documents/digests/bsd-103-understanding-basements/view?searchterm=insulate%20basements
Marcel :slight_smile: :slight_smile:
That’s it but a bit expanded since the last time I was on their site.
Z-girt?
We’re using 3/4" fur strips, so 2" styrofoam is not possible. We are covering with drywall … green board at the bottom and regular drywall on the top. What about paperless drywall? Is it necessary? Our basement is dry.
this website is a bit difficult to navigate … can you provide a link to the page that applies to basement walls?
thanks
Bill, this is what I am talking about.
**Z-Furring **
http://www.dietrichindustries.com/studyguide/images/framingaccess07.gif
**SIZE :1”, 1-1/2”, 2” and 2-1/2”,
GAGE: 25, 20, 18, 16, and 14ga
Applications: Dietrich Z-Furring Channel, made of 25 gage galvanized steel, is used to attach rigid foam insulation and other types of insulation, and gypsum panels, veneer gypsum base or conventional plaster base to inte-rior side of masonry walls. Also used with mineral fiber Z-furring insulation blankets when fire-resistant construction is required.
http://www.dietrichindustries.com/studyguide/images/framingaccess06.gif
Works really well.
Can adhesive be used to attach pink foam board? If so, what type?
Bill, you could try this.
PL300® Foam Board Adhesive
PL300® provides dependable adhesion of foam to all types of surfaces, including wood, fiberglass panels, concrete, brick, metal and drywall. It is compatible with foam board insulation. It permanently joins the foam to the substrate without compromising the insulation value of the foam.
Hope that helps.
