Best way to remember measurements?
During a home inspection, there are many different measurements to remember. Some are self-explanatory and easy to remember, but the measurements can sometimes be jumbled with the mass. What are the best ways you remembered the measurements? Is it solely based off memory? Do you use mnemonics devices? or do you rely on notes? (Sadly, notes won’t help me on the final exam)
A clipboard with NACHI diagrams (egress, main & sub panel diagrams, chimney & flue clearances, etc) plus other notes. Others are self-explanatory within my canned comments; 8 inch ground clearance to siding, 6 inch foundation above grade, etc. all are part of my comments. If I don’t remember the exact number, I find them by a key word search (inch) on my inspection app. I also have notes on what to do if my app crashes and how to recover when I have no wifi or cell coverage.
Take a photo of the tape showing the measurements
That depends on how good your memory is. :grinning:
If you find yourself struggling to remember what numbers get applied where, use a cheat sheet, which can consist of the number written down on a piece of paper to having the numbers in the narrative of the defect in your software, which is what I find myself doing whenever I can’t remember.
For example:
“The chimney didn’t meet the 3-2-10 rule, which is a minimum height requirement for safe operation”.
“The balusters had a space between them that was greater than 4 inches, this condition presents a potential safety hazard for children”.
For the final exam, it’s best to study your weak points over and over until you can remember the numbers.
Look at this and copy and paste all that apply. Use them as flash cards for your studies and print them for clipboard use when you first start out.
And try to search all other calculations not covered here.
Good luck!
Comes from years of experience…but we always double check before we call it out in case we have a memory lapse…
