I have a buyer who wants me to call out ‘black mold’ on the attic insulation. I believe it is dust accumulated from air leakage in a 70 year old house. Is my assessment correct?
Thanks,
Eric
dirt on old insulation , no mold visible in that picture from Ohio, did You lick it to make sure it didn’t taste moldy?
I don’t think its mold lol. Fiberglass isn’t very tasty. Wood sure is, but the wood is clean.
Did your Buyer have a sample tested in a Lab? All he needs is their Report to address it in negotiations. No need to get you involved unless he want’s you to take a sample and send it off to a Lab for analysis… assuming you are qualified and licensed if in a regulated state.
Otherwise…
It’s likely as you suspected and Jim stated above… Dirt filtered from air movement.
Yep, looks like dust/dirt. The insulation is acting as a filter or sorts as air is moving in our out of the space as you say.
Thank you. Would you consider the dirty insulation any kind of defect that you would report on? I typically wouldn’t unless it looked the insulation was significantly degraded or compressed from the dust.
I probably wouldn’t… I see it all the time. It’s just a sign of air passage in/out of an attic which you’ll never totally eliminate.
I do not report on old insulation that has discolored by air transfer unless there is an insufficient amount of it, and then only on the quantity not the color…
yep,lick test is the only way to confirm!
I would likely report on the exposed paper faced insulation.
Warm moist air is entering the knee wall attic space from the adjacent heated room?
Looks like dirt/dust.
It isn’t mold unless a lab says it is. Give your buyer a quote for mold testing. Mine is $300 when on site. $375 if I have to go back.
So, your opinion is that it should be tested based on the OP’s pictures?
No I think if the client thinks it is mold then he should request and pay to have it tested. Otherwise all it is is dirt.
I concur with your hypotheses, Eric.
Atmospheric grime. Dark stains, Atmospheric grime, on insulation is in essence thermal tracking stains indicating air leaks or heat loss.
