St Clair Shores…block basement wall eh
http://picasaweb.google.com/101049034584960315932/June142013BasementWaterproofing
Pic #2. Homeowner was getting water in basement at–along floor/bottom of basement wall…DECK outside, no problem.
4,5. Corner crack, turns into step crack and then into a horizontal crack.
(And NO cracked footing, no SUPPOSED settling issue terdballs)
- Gaps under basement window
7–10 Horizontal crack…water enters into the HOLLOW blocks through these g dang EXTERIOR cracks and other openings…NO interior system, no sump pump fixes/waterproofs these g dang cracks!!! Sheesh!
Hence, water will continue to enter the blocks, period.
- Exterior vertical crack.
No insdie system relieves exterior causes/pressure off the wall that cause many cracks (leaks) and cause cracks to W I D E N, cause walls to bow in.
The Outfield…‘Ya know Bubba likes his girls a little bit older’
